K
kidmanbasha
Hei folkens.Jeg har en design kit men jeg kan egentlig ikke finne parametrene im leter etter i enheten modellen.Nedenfor er enheten modell parametere.Parametrene Jeg leter etter er
1 - GAMMA
2 - LAMBDA
3 - PHI
Jeg kan heller ikke forstå hva setningen etter Vth0 = 1.8602E-01 midler.
Unnskyld min uvitenhet ... Jeg har fortsatt en nybegynner***** Modell Selectors / Controllers *********************************
LEVEL = 4.9000E 01 VERSION = 3.2400E 00
BINUNIT = 2.0000E 00 MOBMOD = 1.0000E 00
CAPMOD = 3.0000E 00 NQSMOD = 0.0000E 00
NOIMOD = 2.0000E 00
***** Process Parametere ******************************************
NGATE = 7.6755E 20 RSH = 9.0000E 00
TOX = '7 ,1300 E-09 DTOX_N_HGLVBPW_33_L130E 'TOXM = 7.1300E-09
XJ = 1.0500E-07 NCH = 9.7100E 16***** Grunnmodellen Parametere **************************************
VTH0 = '1 ,8602 E-01 DVTH0_N_HGLVBPW_33_L130E 'VFB = 1.2758E-00
K1 = 6.6000E-01 K2 = 0.0000E 00
K3 =-4.4000E 00 K3b = 0.0000E 00
W0 = 3.9100E-07 NLX = 2.1800E-07
DVT0 = 1.2867E 00 DVT1 = 4.7170E-01
DVT2 =-1.8700E-01 DVT0W = 1.2250E 00
DVT1W = 1.2398E 07 DVT2W =-3.8770E-01
U0 = '3 ,5220 E-02 DU0_N_HGLVBPW_33_L130E 'UA =-8.0190E-11
UB = 1.4520E-18 UC = 5.0000E-11
VSAT = '9 ,7500 E 04 DVSAT_N_HGLVBPW_33_L130E 'A0 = 8.0000E-01
AGS = 3.0100E-01 B0 = 9.4300E-06
B1 = 2.6900E-05 KETA =-5.0000E-03
A1 = 0.0000E 00 A2 = 9.1000E-01
Wint = '5 ,5600 E-08 DWINT_N_HGLVBPW_33_L130E 'LINT = '2 ,5850 E-08 DLINT_N_HGLVBPW_33_L130E'
DWG =-1.8000E-09 DWB = 1.2100E-09
Voff =-1.2173E-01 NFACTOR = 1.2000E 00
ETA0 = 1.2250E-01 ETAB =-3.0000E-01
DSUB = 1.3559E 00 CIT = 8.5000E-04
CDSC = 0.0000E 00 CDSCB = 0.0000E 00
CDSCD = 1.0000E-04 PCLM = 1.3250E 00
PDIBLC1 = 1.0000E 00 PDIBLC2 = 3.0400E-03
PDIBLCB = 1.0000E-01 DROUT = 1.0000E 00
PSCBE1 = 7.0300E 09 PSCBE2 = 3.5000E-03
PVAG = 6.0000E-01 DELTA = 1.0000E-03***** Parametere for Asymmetrisk og Bias-Dependent Rds Model ******
RDSW = '3 ,8917 E 02 DRDSW_N_HGLVBPW_33_L130E 'PRWB = 5.3200E-02
PRWG = 6.5000E-02 WR = 1.0000E 00***** Impact Ionization Nåværende modell parametre *********************** Gate-Induced Drain Leakage Model Parametere ********************** Gate Dielectric Tunneling Nåværende modell parametre *************** Lad og Capacitance modell parametere *********************
XPART = 1.0000E 00 CGSO = '3 ,9100 E-10 DCGSO_N_HGLVBPW_33_L130E '
CGDO = '3 ,9100 E-10 DCGDO_N_HGLVBPW_33_L130E 'CGBO = 0.0000E 00
CGSL = 0.0000E 00 CGDL = 0.0000E 00
CKAPPA = 6.0000E-01 CF = 0.0000E 00
CLC = 1.0000E-07 CLE = 6.0000E-01
DLC = 8.2000E-08 Dwc = 0.0000E 00
VFBCV = 0.0000E 00 Nøff = 1.9996E 00
VOFFCV =-5.1000E-02 ACDE = 3.8556E-01
MOIN = 2.6250E 00***** High-Speed/RF Model Parametere *********************************** Flicker og termisk Noise Model Parametere ******************
Noia = 9.2795E 20 NOIB = 5.9591E 04
NOIC =-1.0000E-15 EF = 0.8928
EM = 2.6493E 07
***** Layout-Dependent Parasitics modell parametre ****************
XL = 0.0000E 00 XW = 0.0000E 00***** Asymmetrisk Source / Drain Junction Diode Model Parametere *****
JSW = 1.0000E-12 JS = 8.8000E-07
IJTH = 1.0000E-01 CJ = '9 ,7100 E-04 DCJ_N_HGLVBPW_33_L130E '
MJ = 3.5800E-01 MJSW = 2.3000E-01
CJSW = '1 ,0500 E-10 DCJSW_N_HGLVBPW_33_L130E 'CJSWG = '9 ,0000 E-11 DCJSWG_N_HGLVBPW_33_L130E'
MJSWG = 5.0000E-01 PBSW = 6.0000E-01
PB = 6.9100E-01 PBSWG = 6.2000E-01***** Temperatur Dependence Parametere ***************************
TNOM = 2.5000E 01 UTE = 1.4650E-00
KT1 =-3.6500E-01 KT1L = 2.8000E-09
KT2 =-3.2000E-02 UA1 = 3.9700E-10
UB1 =-1.1000E-18 UC1 =-1.0000E-10
PRT = 1.6400E-02 AT = 3.3600E 04
XTI = 3.0000E 00 TPB = 1.4700E-03
TPBSW = 5.9700E-04 TPBSWG = 4.8000E-03
TCJ = 8.8000E-04 TCJSW = 7.9600E-04
TCJSWG = 1.2000E-02***** dW og dL Parametere ****************************************
WL =-1.1100E-14 WLN = 1.0000E 00
WW =-6.0000E-15 WWN = 1.0000E 00
WWL = 1.1100E-21 = LL-3.1250E-17
LLN = 1.0000E 00 LW =-2.2700E-15
LWN = 1.0000E 00 LWL = 7.7500E-26
LLC =-8.8000E-15 LWC = 0.0000E 00
LWLC = 0.0000E 00 WLC = 0.0000E 00
WWC = 0.0000E 00 WWLC = 0.0000E 00***** Range Parametere for Model Søknad **********************
LMIN = 3.4000E-07 Lmax = 5.0000E-05
WMIN = 1.6000E-07 WMAX = 1.0000E-04***** Andre parametere ******************************************* *
ELM = 5.0000E 00 ACM = 1.2000E 01
LDIF = 9.0000E-08 HDIF = 1.3400E-07
CALCACM = 1.0000E 00 LVTH0 = '-1.0118E-08 DLVTH0_N_HGLVBPW_33_L130E'
WVTH0 = '1 ,2000 E-09 DWVTH0_N_HGLVBPW_33_L130E 'PVTH0 ='-4.0600E-16 DPVTH0_N_HGLVBPW_33_L130E '
PK2 = 1.2817E-15 PVSAT = '1 ,0000 E-11 DPVSAT_N_HGLVBPW_33_L130E '
LUA =-6.9514E-18 LUB = 3.3537E-26
PUB =-5.0000E-32 PUC =-4.5000E-24
WU0 = '-6.3600E-11 DWU0_N_HGLVBPW_33_L130E' PU0 = '1 ,1000 E-18 DPU0_N_HGLVBPW_33_L130E '
LKETA = 6.8000E-10 LVOFF =-3.0000E-09
LNFACTOR = 4.5000E-08 PNFACTOR =-8.0000E-15
PDSUB = 1.9800E-14 PPDIBLC2 = 7.6000E-16
LDELTA = 7.5800E-09 PKT1 = 7.5000E-16
LKT2 = 3.9004E-09 PAT =-1.4300E-10
WUTE = 4.1790E-08 pute =-2.0000E-15
WUB1 = 1.1600E-25 PUB1 = 2.0000E-33
PUC1 = 3.0000E-24***** Bruker Drop Parametere ********************************************* High-Speed/RF Model Parametere ******************************
1 - GAMMA
2 - LAMBDA
3 - PHI
NOIMOD = 2.0000E 00
EM = 2.6493E 07
