Jeg får feil når DRC kontrollere, hjelpe meg!
T
tcwxiaoba
/ home / cwtan 6 = PDRACULA
/ home/cad/cadence/ic5141/tools/dracula/bin/32bit/PDRACULA: feil under lasting delte biblioteker: libm.so.6: cannot open shared object file: Ingen slik fil eller mappe
/ home / cwtan 7 = / home/cad/cadence/ic5141/tools/dracula/bin/64bit/PDRACULA
* / N * DRACULA3 (REV. 4.9_64.06-2006 / LNX64 / GENDATE: 6-JUN/2006)
*** (1995 Copyright, Cadence) ***
* / N * EXEC TIME = 21:04:17 DATO = 17-DEC-2009 HOSTNAME = icserver
: / g drc.ev
** MERK: checking for DIMENSJON: 100.000 MIC som er større enn:
90.000 kan potensielt være et problem for svært tett lag
: / f** MERK: misligholde SCALEOUT TIL: 0,001000000 MIC
** LAGE: kommandofilen: jxrun.com
** MERK: Denne jobben har 110 STAGESEND OF DRACULA Samlinger
* 0.129 Mbytes allokert til den aktuelle prosessen.
* 0.129 Mbytes er fortsatt i bruk.
* SLUTTEN AV PROGRAMMET TIME = 21:04:31 DATO = 17-DEC-2009 *
/ home / cwtan 8 = jxrun.com
ulimit: Command not found.
Created On 17-DEC-2009 21:04:17 PDRACULA REV 4.9_64.06-2006 301
0.164u 0.136s 0:00.34 85,2% 0 0 k 0 0 io 0pf 0 w
/ home/cad/cadence/ic5141/tools/dracula/bin/32bit/DRACLM: feil under lasting delte biblioteker: libm.so.6: cannot open shared object file: Ingen slik fil eller mappe
/ home / cwtan 9 = / home/cad/cadence/ic5141/tools/dracula/bin/32bit/DRACLM jxrun.com
* END
/ home/cad/cadence/ic5141/tools/dracula/bin/32bit/GDS2IN: feil under lasting delte biblioteker: libm.so.6: cannot open shared object file: Ingen slik fil eller mappe
takk for at du svarer!
Det ser ut som en dekompilere eller UNIX C bibliotekene oppsett problem.Eller baner.
Eller baner.
