teknologi TSMC med N-brønn-og P-brønnen i samme substratet
F
fasto2008
HALLO,
Jeg
er så lei meg for min engelsk skriftlig men
jeg er glad for å høre på deg.
Den TSMC fabrikasjon prosesser tilgjengelig gjennom MOSIS (gir tilgang til fabrikasjon av prototype)
inkludere 0,35 lm CMOS, 0,25 lm CMOS, 0,18 lm CMOS og 0,13 lm CMOS.
Jeg velger:
TSMC 0,18 lm
prosessen: CR018 (CM018)
Beskrivelse: Mixed-mode/RF, RPO, MiM
Jeg finner mange parametere: (http://www.mosis.com/Technical/Testdata/tsmc-018-prm.html)
T77A_MM_NON_EPI_THK-MTL_HR8
T77A_MM_NON_EPI
T73D_MM_NON_EPI
T73D_MM_NON_EPI_THK-MTL
T6CA_MM_NON_EPI_THK-MTL_HR8
T6CA_MM_NON_EPI
T68B_MM_NON_EPI
T68B_MM_NON_EPI_THK-MTL
T66D_MM_NON_EPI_THK-MTL
T66D_MM_NON_EPI
T64H_MM_NON_EPI_THK-MTL
T64H_MM_NON_EPI
T64H_LO_EPI
T58F_MM_NON_EPI_THK-MTL
T58F_MM_NON_EPI
T58F_LO_EPI
T57Q_MM_NON_EPI_THK-MTL
T57Q_MM_NON_EPI
T57Q_LO_EPI
T55U_MM_NON_EPI
T55U_MM_NON_EPI_THK-MTL
T55U_LO_EPI
T53R_MM_NON_EPI_THK-MTL
T53R_MM_NON_EPI
T53R_LO_EPI
T4BK_MM_NON_EPI_THK-MTL
T4BK_LO_EPI
T4BK_MM_NON_EPI
T49P_LO_EPI
T49P_MM_NON_EPI_THK-MTL
T49P_MM_NON_EPI
T47R_MM_NON_EPI_THK-MTL
T47R_MM_NON_EPI
T46U_MM_NON_EPI_THK-MTL
T46U_MM_NON_EPI
T46U_LO_EPI
T44E_MM_NON_EPI
T44E_MM_NON_EPI_THK-MTL
T44E_LO_EPI
T42P_MM_NON_EPI_THK-MTL
T42P_MM_NON_EPI
T42P_LO_EPI
T3CV_MM_NON_EPI
T3CV_LO_EPI
T3CV_MM_NON_EPI_THK-MTL
T3AZ_MM_NON_EPI_THK-MTL
T3AZ_MM_NON_EPI
T3AZ_LO_EPI
T38N_MM_NON_EPI
T38N_MM_NON_EPI_THK-MTL
T38N_LO_EPI
T36Q_MM_NON_EPI
T36Q_MM_NON_EPI_THK-MTL
T36Q_LO_EPI
T34B_MM_NON_EPI
T34B_MM_NON_EPI_THK-MTL
T34B_LO_EPI
T32L_MM_NON_EPI
T32L_MM_NON_EPI_THK-MTL
T2CU_MM_NON_EPI_THK-MTL
T2CU_MM_NON_EPI
T2CU_LO_EPI
T29B_MM_NON_EPI
T29B_MM_NON_EPI_THK-MTL
T29B_LO_EPI
T28M_MM_NON_EPI_THK-MTL
T28M_LO_EPI
T28M_MM_NON_EPI
T26X_LO_EPI
T26X_MM_NON_EPI_THK-MTL
T26X_MM_NON_EPI
T24I_MM_NON_EPI_THK-MTL
T24I_MM_NON_EPI
T24I_LO_EPI
T22T_MM_NON_EPI
T22T_MM_NON_EPI_THK-MTL
T22T_LO_EPI
T1CH_MM_NON_EPI_THK-MTL
T1CH_MM_NON_EPI
T1CH_LO_EPI
T1AX_MM_NON_EPI_THK-MTL
T1AX_MM_NON_EPI
T1AX_LO_EPI
T18H_LO_EPI
T18H_MM_NON_EPI
T18H_MM_NON_EPI_THK-MTL
T16X_LO_EPI
T16X_MM_NON_EPI
T16X_MM_NON_EPI_THK-MTL
T15J_MM_NON_EPI
T15J_LO_EPI
T14B_LO_EPI
T14B_MM_NON_EPI
T12K_MM_EPI
T12K_LO_EPI
T11B_LO
T11B_MM
EPI = Epitaxial wafers
NON_EPI = Ikke epitaxial wafers
LO = Logic prosessen
MM = Mixed-mode prosessen
THK-MTL = Tykt metall alternativet (MM only)
Målet er å ha N-brønn-og p-brønn i samme underlaget.
Problemet er at når jeg kommer til alle dem jeg ikke finne p-brønnen parametere.
Takk for hjelpen.
Ok, så jeg forstår at du har epitaxial lag som brønner ... I dette tilfellet p godt er det, der det ikke er n-vel ...
De fleste av de tilfellene som er tilfellet ...
Så igjen, underlaget (p-type) og det er en epitaxial p-brønn og en epitaxial n-brønn på underlaget
Hvis du har en trippel vel prosessen, da har du n-brønn-og p-brønnen laget beskrivelser, i dette tilfellet kan du bruke forskjellige masseendringer spenninger for p-brønner
